Skype Outbound Calls Problem
Discussion in '3CX Phone System - General' started by alessio.f, Feb 8, 2011.
  1. alessio.f
    Feb 8, 2011
    Hi to all,
    I'm new here and I'm trying to configure a simple VoIP system for my house.
    I've got a Linksys 942 that i've already configured, a 3cx server with 3cx gateway for skype configured with an already existing account with an active credit of some euros.
    In the 3cx server I've created the outbound roule with "0" so, on the 942 when I call 0echo123 I reach successfully the skype echo test.
    So I've try to call a friend of my with the same rule 0skypecontact but the phone say to me "NetworkError"
    Then I've tryed to call my phone number using the same rule 00039xxxxxxxx it says "Phone is ringing" but then after a ring it suddenly says ServerInternalError.
    How can I handle this?
    Thank you all in advance,
    -Alessio
  2. alessio.f
    Feb 8, 2011
    Sorry, this is my log,
    10:11:10.806 [CM503020]: Normal call termination. Reason: Terminated
    10:11:10.806 [CM503016]: Call(64): Attempt to reach <sip:00039XXXXXXXXX@192.168.1.10> failed. Reason: User Requested
    10:11:10.806 [CM503003]: Call(64): Call to sip:0039XXXXXXXXX@127.0.0.1:6060 has failed; Cause: 200 OK; from IP:127.0.0.1:6060
    10:11:09.697 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    10:11:09.697 [CM503002]: Call(64): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    10:11:09.540 [CM503025]: Call(64): Calling PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:11:09.509 [CM503004]: Call(64): Route 1: PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:11:09.494 [CM503010]: Making route(s) to <sip:00039XXXXXXXXX@192.168.1.10>
    10:11:09.494 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    10:11:09.494 [CM503001]: Call(64): Incoming call from Ext.6001 to <sip:00039XXXXXXXXX@192.168.1.10>
    10:10:57.962 [CM503008]: Call(63): Call is terminated
    10:10:55.759 [CM503007]: Call(63): Device joined: sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    10:10:55.759 [CM503007]: Call(63): Device joined: sip:6001@192.168.1.200:5060
    10:10:54.853 Currently active calls - 1: [63]
    10:10:53.134 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    10:10:53.134 [CM503002]: Call(63): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    10:10:52.994 [CM503025]: Call(63): Calling PSTNline:echo123@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:10:52.947 [CM503004]: Call(63): Route 1: PSTNline:echo123@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:10:52.947 [CM503010]: Making route(s) to <sip:0echo123@192.168.1.10>
    10:10:52.947 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    10:10:52.931 [CM503001]: Call(63): Incoming call from Ext.6001 to <sip:0echo123@192.168.1.10>
    10:03:30.025 [CM503020]: Normal call termination. Reason: Terminated
    10:03:30.025 [CM503016]: Call(62): Attempt to reach <sip:00039XXXXXXXXX@192.168.1.10> failed. Reason: User Requested
    10:03:30.025 [CM503003]: Call(62): Call to sip:0039XXXXXXXXX@127.0.0.1:6060 has failed; Cause: 200 OK; from IP:127.0.0.1:6060
    10:03:28.915 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    10:03:28.915 [CM503002]: Call(62): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    10:03:28.759 [CM503025]: Call(62): Calling PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:03:28.728 [CM503004]: Call(62): Route 1: PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:03:28.728 [CM503010]: Making route(s) to <sip:00039XXXXXXXXX@192.168.1.10>
    10:03:28.712 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    10:03:28.712 [CM503001]: Call(62): Incoming call from Ext.6001 to <sip:00039XXXXXXXXX@192.168.1.10>
    10:03:10.415 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.1.10:5060
    10:02:58.697 [CM503020]: Normal call termination. Reason: Terminated
    10:02:58.697 [CM503016]: Call(61): Attempt to reach <sip:00039XXXXXXXXX@192.168.1.10> failed. Reason: User Requested
    10:02:58.697 [CM503003]: Call(61): Call to sip:0039XXXXXXXXX@127.0.0.1:6060 has failed; Cause: 200 OK; from IP:127.0.0.1:6060
    10:02:57.790 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    10:02:57.790 [CM503002]: Call(61): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    10:02:57.634 [CM503025]: Call(61): Calling PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:02:57.603 [CM503004]: Call(61): Route 1: PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    10:02:57.603 [CM503010]: Making route(s) to <sip:00039XXXXXXXXX@192.168.1.10>
    10:02:57.587 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    10:02:57.587 [CM503001]: Call(61): Incoming call from Ext.6001 to <sip:00039XXXXXXXXX@192.168.1.10>
    09:43:27.650 [CM503008]: Call(60): Call is terminated
    09:43:24.150 [CM503007]: Call(60): Device joined: sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    09:43:24.150 [CM503007]: Call(60): Device joined: sip:6001@192.168.1.200:5060
    09:43:19.915 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    09:43:19.915 [CM503002]: Call(60): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    09:43:19.775 [CM503025]: Call(60): Calling PSTNline:echo123@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:43:19.728 [CM503004]: Call(60): Route 1: PSTNline:echo123@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:43:19.728 [CM503010]: Making route(s) to <sip:0echo123@192.168.1.10>
    09:43:19.728 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    09:43:19.712 [CM503001]: Call(60): Incoming call from Ext.6001 to <sip:0echo123@192.168.1.10>
    09:43:10.322 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.1.10:5060
    09:42:35.009 [CM503020]: Normal call termination. Reason: Terminated
    09:42:35.009 [CM503016]: Call(59): Attempt to reach <sip:00039XXXXXXXXX@192.168.1.10> failed. Reason: User Requested
    09:42:35.009 [CM503003]: Call(59): Call to sip:0039XXXXXXXXX@127.0.0.1:6060 has failed; Cause: 200 OK; from IP:127.0.0.1:6060
    09:42:34.103 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    09:42:34.103 [CM503002]: Call(59): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    09:42:33.962 [CM503025]: Call(59): Calling PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:42:33.915 [CM503004]: Call(59): Route 1: PSTNline:0039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:42:33.915 [CM503010]: Making route(s) to <sip:00039XXXXXXXXX@192.168.1.10>
    09:42:33.915 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    09:42:33.900 [CM503001]: Call(59): Incoming call from Ext.6001 to <sip:00039XXXXXXXXX@192.168.1.10>
    09:42:20.744 [CM503020]: Normal call termination. Reason: Not found
    09:42:20.744 [CM503016]: Call(58): Attempt to reach <sip:5echo123@192.168.1.10> failed. Reason: Not Found
    09:42:20.744 [CM503014]: Call(58): No known route to target: <sip:5echo123@192.168.1.10>
    09:42:20.744 [CM503010]: Making route(s) to <sip:5echo123@192.168.1.10>
    09:42:20.744 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    09:42:20.744 [CM503001]: Call(58): Incoming call from Ext.6001 to <sip:5echo123@192.168.1.10>
    09:42:07.603 [CM503020]: Normal call termination. Reason: Not found
    09:42:07.603 [CM503016]: Call(57): Attempt to reach <sip:5039XXXXXXXXX@192.168.1.10> failed. Reason: Not Found
    09:42:07.603 [CM503014]: Call(57): No known route to target: <sip:5039XXXXXXXXX@192.168.1.10>
    09:42:07.603 [CM503010]: Making route(s) to <sip:5039XXXXXXXXX@192.168.1.10>
    09:42:07.603 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    09:42:07.603 [CM503001]: Call(57): Incoming call from Ext.6001 to <sip:5039XXXXXXXXX@192.168.1.10>
    09:41:55.462 [CM503020]: Normal call termination. Reason: Not found
    09:41:55.462 [CM503016]: Call(56): Attempt to reach <sip:50039XXXXXXXXX@192.168.1.10> failed. Reason: Not Found
    09:41:55.462 [CM503014]: Call(56): No known route to target: <sip:50039XXXXXXXXX@192.168.1.10>
    09:41:55.447 [CM503010]: Making route(s) to <sip:50039XXXXXXXXX@192.168.1.10>
    09:41:55.447 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    09:41:55.447 [CM503001]: Call(56): Incoming call from Ext.6001 to <sip:50039XXXXXXXXX@192.168.1.10>
    09:40:55.150 [CM503020]: Normal call termination. Reason: Not available
    09:40:55.150 [CM503016]: Call(55): Attempt to reach <sip:0039XXXXXXXXX@192.168.1.10> failed. Reason: Temporarily Unavailable
    09:40:55.150 [CM503003]: Call(55): Call to sip:039XXXXXXXXX@127.0.0.1:6060 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6060
    09:40:55.134 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    09:40:55.134 [CM503002]: Call(55): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    09:40:54.994 [CM503025]: Call(55): Calling PSTNline:039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:40:54.947 [CM503004]: Call(55): Route 1: PSTNline:039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:40:54.947 [CM503010]: Making route(s) to <sip:0039XXXXXXXXX@192.168.1.10>
    09:40:54.947 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    09:40:54.931 [CM503001]: Call(55): Incoming call from Ext.6001 to <sip:0039XXXXXXXXX@192.168.1.10>
    09:39:34.306 [CM503020]: Normal call termination. Reason: Not available
    09:39:34.306 [CM503016]: Call(54): Attempt to reach <sip:0039XXXXXXXXX@192.168.1.10> failed. Reason: Temporarily Unavailable
    09:39:34.306 [CM503003]: Call(54): Call to sip:039XXXXXXXXX@127.0.0.1:6060 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6060
    09:39:34.306 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    09:39:34.306 [CM503002]: Call(54): Alerting sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d
    09:39:34.150 [CM503025]: Call(54): Calling PSTNline:039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:39:34.103 [CM503004]: Call(54): Route 1: PSTNline:039XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:39:34.103 [CM503010]: Making route(s) to <sip:0039XXXXXXXXX@192.168.1.10>
    09:39:34.103 [CM503001]: Call(54): Incoming call from Ext.6001 to <sip:0039XXXXXXXXX@192.168.1.10>
    09:39:22.400 [CM503016]: Call(53): Attempt to reach <sip:0XXXXXXXXX@192.168.1.10> failed. Reason: Temporarily Unavailable
    09:39:22.384 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    09:39:22.244 [CM503025]: Call(53): Calling PSTNline:XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:39:22.197 [CM503010]: Making route(s) to <sip:0XXXXXXXXX@192.168.1.10>
    09:39:22.197 [CM503001]: Call(53): Incoming call from Ext.6001 to <sip:0XXXXXXXXX@192.168.1.10>
    09:39:13.869 [CM503016]: Call(52): Attempt to reach <sip:039XXXXXXXXX@192.168.1.10> failed. Reason: Temporarily Unavailable
    09:39:13.869 [CM505002]: Gateway:[SkypeGW] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    09:39:13.712 [CM503025]: Call(52): Calling PSTNline:39XXXXXXXXX@(Ln.10000@SkypeGW)@[Dev:sip:10000@127.0.0.1:6060;rinstance=b228a1d2f78f832d]
    09:39:13.665 [CM503010]: Making route(s) to <sip:039XXXXXXXXX@192.168.1.10>
    09:39:13.665 [CM505001]: Ext.6001: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:6001@192.168.1.10:5060]
    Thanks again,
    -Alessio
  3. leejor
    10,565
    245
    Are you sure that you are sending the correct digits to Skype?
