Skype Support
Discussion in '3CX Phone System - General' started by DuNuNuBatman, Dec 3, 2010.
  1. DuNuNuBatman
    Feb 26, 2007
    13
    Is the Skype gateway software still required? I noticed that Skype is listed as a voip provider in the management menu.
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    The Skype mentioned in the Management Console is for Skype Connect...
    http://www.skype.com/intl/en-us/business/sip/overview/
    ... so for standard Skype you still need the gateway.
