Skype to Skype calls is busy
Discussion in '3CX Phone System - General' started by vm, Oct 13, 2009.
  1. vm
    vm
    Mar 17, 2009
    5
    Hello everyone, I have a problem with outgoing calls from Skype to Skype, when I make a Skype call the recipient's rings, but if the recipient answers the call line is dropped
    This is the log of 3CX:
    08:28:01.062 [CM503008]: Call(34): Call is terminated
    08:27:55.625 [CM503016]: Call(34): Attempt to reach <sip:xxx.skype.id@127.0.0.1:5060> failed. Reason: Busy
    08:27:55.625 [CM503003]: Call(34): Call to sip:xxx.skype.id@127.0.0.1:6060 has failed; Cause: 486 Busy Here; from IP:127.0.0.1:6060
    08:27:52.515 [CM505002]: Gateway:[skype-01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] PBX contact: [sip:10002@127.0.0.1:5060]
    08:27:52.515 [CM503002]: Call(34): Alerting sip:10002@127.0.0.1:6060;rinstance=f239c3ccb6796ac3
    08:27:52.359 [CM503025]: Call(34): Calling PSTNline:xxx.skype.id@(Ln.10002@skype-01)@[Dev:sip:10002@127.0.0.1:6060;rinstance=f239c3ccb6796ac3]
    08:27:52.312 [CM503004]: Call(34): Route 1: PSTNline:xxx.skype.id@(Ln.10002@skype-01)@[Dev:sip:10002@127.0.0.1:6060;rinstance=f239c3ccb6796ac3]
    08:27:52.312 [CM503010]: Making route(s) to <sip:xxx.skype.id@127.0.0.1:5060>
    08:27:52.312 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA921-5.1.5] PBX contact: [sip:100@172.16.10.2:5060]
    08:27:50.468 [CM503007]: Call(34): Device joined: sip:100@172.16.10.40:5060
    08:27:50.203 [CM503007]: Call(34): Device joined: sip:MakeCall@127.0.0.1:40600;rinstance=9bcefb7a65e2985c
    08:27:50.203 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA921-5.1.5] PBX contact: [sip:100@172.16.10.2:5060]
    08:27:50.203 [CM503002]: Call(34): Alerting sip:100@172.16.10.40:5060
    08:27:49.390 [CM503025]: Call(34): Calling Ext:Ext.100@[Dev:sip:100@172.16.10.40:5060]
    08:27:49.343 [CM503004]: Call(34): Route 1: Ext:Ext.100@[Dev:sip:100@172.16.10.40:5060]
    08:27:49.343 [CM503010]: Making route(s) to <sip:100@127.0.0.1:5060>
    08:27:49.343 [CM505001]: Ext.MakeCall: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX MakeCall helper] PBX contact: [sip:MakeCall@127.0.0.1:5060]
    08:27:49.343 [CM503001]: Call(34): Incoming call from Ext.MakeCall to <sip:100@127.0.0.1:5060>
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    A very useful test is to call Skype's sound service, echo123, which is obviously a Skype account. Please do this test and tell us the result.
  3. vm
    vm
    Mar 17, 2009
    5
    If I call echo123 the number is busy ...
    I have installed 3CX v8.9414 on a PC with XP prof sp3, the skype gateway is installed on the same PC of 3CX Phone System, i make the call from a pc client with 3cx assistant
    09:22:50.609 [CM503008]: Call(37): Call is terminated
    09:22:45.171 [CM503016]: Call(37): Attempt to reach <sip:echo123@127.0.0.1:5060> failed. Reason: Busy
    09:22:45.171 [CM503003]: Call(37): Call to sip:echo123@127.0.0.1:6060 has failed; Cause: 486 Busy Here; from IP:127.0.0.1:6060
    09:22:42.812 [CM505002]: Gateway:[skype-01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] PBX contact: [sip:10002@127.0.0.1:5060]
    09:22:42.812 [CM503002]: Call(37): Alerting sip:10002@127.0.0.1:6060;rinstance=f239c3ccb6796ac3
    09:22:42.609 [CM503025]: Call(37): Calling PSTNline:echo123@(Ln.10002@skype-01)@[Dev:sip:10002@127.0.0.1:6060;rinstance=f239c3ccb6796ac3]
    09:22:42.562 [CM503004]: Call(37): Route 1: PSTNline:echo123@(Ln.10002@skype-01)@[Dev:sip:10002@127.0.0.1:6060;rinstance=f239c3ccb6796ac3]
    09:22:42.546 [CM503010]: Making route(s) to <sip:echo123@127.0.0.1:5060>
    09:22:42.546 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA921-5.1.5] PBX contact: [sip:100@172.16.10.2:5060]
    09:22:41.078 [CM503007]: Call(37): Device joined: sip:100@172.16.10.40:5060
    09:22:40.750 [CM503007]: Call(37): Device joined: sip:MakeCall@127.0.0.1:40600;rinstance=9bcefb7a65e2985c
    09:22:40.750 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA921-5.1.5] PBX contact: [sip:100@172.16.10.2:5060]
    09:22:40.750 [CM503002]: Call(37): Alerting sip:100@172.16.10.40:5060
    09:22:39.218 [CM503025]: Call(37): Calling Ext:Ext.100@[Dev:sip:100@172.16.10.40:5060]
    09:22:39.171 [CM503004]: Call(37): Route 1: Ext:Ext.100@[Dev:sip:100@172.16.10.40:5060]
    09:22:39.171 [CM503010]: Making route(s) to <sip:100@127.0.0.1:5060>
  4. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Ok, now I need two more informations:
    1- in the gateway console, all channels Skypes are "Online-On Hook"?
    2 - if your gateway is configured with a master channel, the outbound call you made is to the master one?
  5. vm
    vm
    Mar 17, 2009
    5
    In the skype gateway I have only one channel configured as master and the state is "Online-On Hook".... the outgoing calls to Skype using this gateway
  6. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Ok, then stop the gateway, edit the channel and make it a "normal" one (no "master") then try it again to see if it works.
  7. vm
    vm
    Mar 17, 2009
    5
    Perfect !!!!! thank you very much !
