Skype Video
Discussion in '3CX Phone System - General' started by big, Oct 21, 2009.
  1. big
    big
    Oct 13, 2009
    Does the 3CX Gateway support Skype video and H264 codecs ?
    thanks,
    John
  2. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i would like to know this also?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    For their client, Skype provide APIs for audio control only, for video - not. Therefore, passing video through the gateway is not possible.
  4. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    http://skystonevideo.imagicle.com/Home.aspx
  5. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    at $1500 per channel (and this is on offer for the pilot) i will do without.
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    the concept is quite good.
    the question is why "4 channels" requires "4 cores" and why it is available only for w2003 servers?
    What is the problem to use Vista/2008/W7 to advertise new product?
