skype
Discussion in '3CX Phone System - General' started by aftermarket, May 21, 2009.
  1. aftermarket
    May 13, 2009
    84
    managed to get skype all connected and working well kinda. when someone calls via skype the phones ring however when they are picked up i can hear the other person then the call drops after 27 seconds as the 3cx where skype is installed doesnt pick the call up itself. if i manuely click answer on the 3cx server the calls last as long as it should . what have i done worng.
