SKYPE
Discussion in '3CX Phone System - General' started by phoneguy, Aug 28, 2012.
  1. phoneguy
    Aug 28, 2012
    Do I understand correctly that 3CX will not interface with the latest versions of SKYPE?
    11,117
    329
    Correct, if you wish to use the 3CX Skype Gateway programme, you must use an earlier version of Skype (and set it to NOT upgrade). If you do a search of the forum, the working version numbers are mentioned. They can still be found for download by doing a Google search.
