Skype2sip or stonevoice
Discussion in '3CX Phone System - General' started by knops, Aug 22, 2007.
  1. knops
    Aug 22, 2007
    7
    I have installed 3cx and it work perfectly!!!!
    But I have somes questions.
    I see on the forum :
    http://www.3cx.com/forums/viewtopic.php?t=1948&highlight=skype2sip
    http://www.3cx.com/forums/viewtopic.php?t=216&highlight=skype
    And other.
    I want to do SkypeOut call through 3cx, with un special first number ( 8 ) to indicate that this call must be do with skype.
    My phone number is : (exemple) 0041223334455 And if I do the number : 80041223334455 this call (to : 0041223334455) must be call by skype.
    (sorry for my explanation and my English :) ).
    My server ip is : 10.5.5.2
    I have install Uplink skype2sip
    I have add an PSTN line with the number 5050
    gateway : 10.5.5.2
    Virtual extension : 5050
    Authentication ID : 5050
    pass : 123
    at the End the wizard ad a Outbound Rules "rule for ..." Number prefix "8" , transform mask "r".
    Then, in uplink skype2sip, I add the sip configuration :
    user : 5050
    Pass : 123
    domaine : 10.5.5.2
    skype2sip can connect, and is in green in the line status.
    In the line status I have my other extension, ex: 5061 (connected and work with Xlite.)
    Now , if a do a call with : 8xxxxx or 80041223334455
    Xlite say : call unavailable and write : Forbidden.
    If I call : 5050 -> temporarily Unvailable
    Logs in serversatus:
    1er test 80041xxxx
    11:44:46.640 CallConf::Rejected [CM103005] Call(13) is rejected: Invalid password provided
    11:44:46.640 StratInOut::eek:nCancel [CM104008] Call(13): Call from Ext.5061 to 0041223334455 terminated; cause: 403 Invalid password provided; from IP:10.5.5.2
    11:44:46.546 AuthMgr::eek:nAuthFailure [CM101000] Registration request from sip:5061@10.5.5.2:5060 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    11:44:46.546 AuthMgr::requestCredential [CM001005] Message SipReq: INVITE 0041223334455@10.5.5.2:5060 tid=a6227263c3678c2d cseq=INVITE contact=5061@10.5.5.2:5060 / 2 from(wire) failed authentication!
    11:44:46.546 AuthMgr::requestCredential [CM001001] Authentication ID for CfgExt:5061 doesn't match provided: 5050 vs 5061
    second : 5050 :
    11:42:14.890 CallConf::eek:nIncoming [CM003002] Call(12): Destination not available for call from sip:5061@10.5.5.2 to sip:5050@10.5.5.2
    11:42:14.890 StratInOut::initialize [CM004003] Call(12): Can't call external line DN
    Any Idee?
    An other solution to do call with skype?
    Knops
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Account is not properly configured on X-lite. It uses UserID 5050 instead of 5061 specified in PBX configuration.
  3. knops
    Aug 22, 2007
    7
    If i do somes call from 2pc with X-lite, there are no problem.
    ex : pc1 (5061)
    pc2 (5062)
    I can do a call
  4. knops
    Aug 22, 2007
    7
    In line manager, "manage gateway & provider" y have my line, "SkypeOutUplink
    type : PSTN.
    In "Registration settings"
    I have Check, the checkbock :
    Use registration's 'Contact' field host/port instead host/port specified in configuratio
    and in "Require (optionally: authorized) registration for:"
    I have checked "Require (optionally: authorized) registration for:"
    Now I don't have the problme of authetication. but
    I have that in my logs :
    14:01:36.234 StratInOut::eek:nHangUp [CM104007] Call(32): Call from Ext.5061 to 0041223334455 has been terminated by Ext.5061; cause: CANCEL; from IP:10.5.5.2
    14:01:24.265 CallConf::eek:nIncoming [CM103002] Call(32): Incoming call from 5061 (Ext.5061) to sip:80041223334455@10.5.5.2
    Nothing passed :(
    Any Idee?
    Knops
  5. knops
    Aug 22, 2007
    7
    the problem was in the network configuration of uplink skype2sip.
    in setting -> network
    i must desabled the checkbox :
    "use uPNP to find..."
    and
    "usr STUN servers to find..."
    Now it work. :)
    Hihi
    Bye
    Knops
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    How much does the software cost from stonevoice may i ask? How many lines does it support? Just for our reference :)
  7. knops
    Aug 22, 2007
    7
    Sorry, i don't Know because I can't use the trial version,
    and uplink skype2sip work correctly now :)
    sorry
  8. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Hi Nick,
    NCH Software is currently selling Uplink Skype2SIP for US$27.50 though in the past I believe the claim on their site of a price of US$55 to be true. I did purchase this myself and got it working OK fairly easily, but I would not call it plug and play :lol:
    No real use for it though, I wasted my money. To use Skype via Uplink you must key "00" before any number, no problem with configuring rules to add it, but also blocks having any traditional USA/Canada VoIP provider as a backup in the same rule. Also, maybe just me, but I feel call quality is poor compared even to cheaper VoIP providers.
    Mirza.
