SLA
Discussion in '3CX Phone System - General' started by Meggie, Feb 28, 2017.
  1. Meggie
    Feb 21, 2017
    6
    I need an information about SLA. As I know it is service level agreement, and want to know how you calculate it in your report?
  2. GiannosC_3CX
    GiannosC_3CX Guest
  3. Meggie
    Feb 21, 2017
    6
    How sla is calculated in your report?
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Meggie,
    Sorry for the above link is wrong, this is the correct link https://www.3cx.com/3cxacademy/videos/intermediate/call-queues/ on slide 17.
    Please note the SLA time must be set under Queue Preferences on Advanced option on queue settings.
    If the call remains in the queue more than the time that you specified in the SLA time field then the system will calculate the calls that breached that SLA time.
  5. Meggie
    Feb 21, 2017
    6
    I think you gave me a wrong link again. Can you tell exactly what is SLA time? you mean 80/20?
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Meggie,
    The SLA time (Service Level Agreement) is the amount of time you commit to answer the call, as per company policy (that is, the queue supervisors or management decide that they want all calls to be answered within a certain amount of time) in seconds.
    It is just a threshold you set, for example 120 seconds, meaning that you commit as a company to answer all calls before 120 seconds, or 2 minutes.
    Techops likes this.
  7. Meggie
    Feb 21, 2017
    6
    thank you very much for the information.
  8. Greg Nurnberger
    Feb 13, 2017
    Hi, was wondering if there is a way to determine which agent or agents did not answer the call that breached the SLA.
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    There is no specific way to achieve this as there is a report for abandoned Q calls the will let you know of the agent and how many times he has been polled but the call has to be abandoned not just breached the SLA. You can request for a report that does that in our ideas section of the forum and if it gets enough votes and it is technically possible it might get implemented in a future release.
  10. Greg Nurnberger
    Feb 13, 2017
    That is what I thought. Thank you for the reply.
