Slow DDS Key XML browser execution
Discussion in '3CX Phone System - General' started by vondie, Aug 15, 2017.
  1. vondie
    Oct 16, 2013
    16
    We have two buttons programmed on our Yealink T38 operator station to easily set the phone to away or available. We have been using this setup for several years up to 3cx version 12. We have recently upgraded to v15.5 and the same configuration using the same XML files are really slow to execute. In V12, the button press to completion was about 2 seconds. With V15.5, it can take almost 10 seconds. Doesn't sound like much, but we frequently get incoming calls that will interrupt the execution which defeats the purpose of having the ability to quickly set the status to away. Here is the setup.
    Key Type Value
    DSS9 XML Browser https://<3cx-IP>:5001/provisioning/xxxxxxxxxxx/away.xml
    away.xml file
    <?xml version="1.0" encoding="UTF-8"?>
    <YealinkIPPhoneExecute Beep="yes">
    <ExecuteItem URI="Led:MEMO10_GREEN=off"/>
    <ExecuteItem URI="Led:MEMO9_GREEN=on"/>
    <ExecuteItem URI="Dial:*31" interrupetCall="no"/>
    </YealinkIPPhoneExecute>
  2. vondie
    Oct 16, 2013
    16
    Credit goes to complex1 on the Yealink forums. He suggested using http://<3cx-IP>:5000/provisioning/xxxxxxxxxxx/away.xml to bypass the certification method used in v15.5. The environment now works like it did under v12.
