Small on-prem system? up^2, APU2C4 or NUC?
Discussion in '3CX Phone System - General' started by dandenson, Mar 12, 2018.
  1. dandenson
    dandenson New Member
    Mar 1, 2018
    155
    17
    Looking for some very small wall-mountable options for a 4 channel 3CX system advice.
    The hardware specs start at 16 channels and an i3. Not sure what is actually needed to run a 4 channel PBX.
    I've used a lot of the APU2C4 boards for freepbx systems and they work great. They are quad 1Ghz though. The UP boards are pretty similar but with Atom CPUs (until the more expensive units).
    Are these acceptable CPU wise? Or do I need to get into an i3? And if so, any suggestions on a low-cost, wall mountable option?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
  3. dandenson
    Mar 1, 2018
    155
    17
    great, thanks!
  4. StefanW
    Jun 2, 2009
    1,216
    88
    should I say that I have one of those and run a test system on it?
    So far stable but I dont have production workload. Only the null modem cable setup is a bit of work...
  5. dandenson
    Mar 1, 2018
    155
    17
    one of what StefanW?
  6. dandenson
    Mar 1, 2018
    155
    17
    The AMD GX-412HC ( in the APU) has a passmark score of 1497, the N3050 is only 882. Thats 4 core vs 2 core so there's a bit of a loss on single thread performance in that one benchmark but that suggests the APU is likely a better platform.
    It's a super solid platform. I can run 20 concurrent g.711 calls on this with asterisk and 100 registrations with low system load.
