SMDR Output
Discussion in '3CX Phone System - General' started by chrisc54, Jun 18, 2008.
  1. chrisc54
    Jun 18, 2008
    Hello, I might of missed something but is there a way that when running 3cx it can log calls via an SMDR output on a COM port? or if not a work around?
    3cx looks just what we are after, but we have a computer system that requires SMDR output to look up customer details on incoming calls and although i think this is great, i will never get away with loosing this functionailty.
    Any advice appreciated!
    Aaron Falzon likes this.
  2. chrisc54
    Jun 18, 2008
    Basically we are running some software which we use as the main business app. This software takes a feed from an SMDR output & when an extension is answered, using CLI looks up the callers details from a database (from when they last called)
    Problem is that there is no way of changing this application, it has to use a feed in the format of SMDR. I might be missing something if there is another way to get this kid of information (in real time) from 3cx?
    chris
