SMS Alert for Vicemail
Discussion in 'Windows' started by brad, Jul 17, 2014.
  1. brad
    Jul 17, 2014
    We have our 3cx setup with a an after hours rule that routes to a digital receptionist, plays a message and then routes to an extensions voicemail. The voicemail's for this extension automatically get forwarded to an email.
    What we would like is an SMS notification as well as the email notification that a voicemail has been left.
    I've come across the Voice Application Designer. Does this come with the 3cx software or is it additional?
    I see i can get an add-in for the VAD, maybe this will work?
    http://www.utahvoipstore.com/Products/130-vadtools-custom-component-for-the-3cx-voice-application-designer-send-a-text-message-from-your-ivr.aspx
    Brad
  2. 3CXNP
    3CXNP Support Team
    3CX Support
    Apr 25, 2014
    44
    Hi Brad,
    the 3CX Voice Application Designer is additional, and can be purchased from a regional 3CX partner.
    Best regards,
  3. brad
    Jul 17, 2014
    Thanks for the reply but i found the download, just have to figure out how to add in an SMS component
  4. leejor
    11,293
    361
    While it's not widely publicized, many mobile providers have an option to send a short email (mobilenumber@myprovider.com) to one of their mobiles as an SMS. You might want to ask your mobile provider if they offer this , it might save you some effort.
  5. asmith3006
    Mar 5, 2014
    94
    5
    Lots of web based SMS gateways exist and you can send them an email from a "pre-approved" email address to send emails. Or if you're using the VAD you could make a web call to send an SMS.
    We use a company called www.txtlocal.co.uk for our SMS sending, they've proven very reliable and their prices are good (I don't work for them, nor earn commission from any recommendation).
