SMTP without login
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Dec 9, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Is it possible with the way the email component works to send email without a login to the SMTP serve?
    10,371
    230
    My providers SMTP server doesn't require a login, but using it requires that you be on their network. If you are talking about an SMTP server not hosted by your ISP, then probably no, as that would allow unauthorised users to relay SPAM.
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Currently the EMail Sender component always uses a login. We'll make a change so when you leave that empty, we'll connect to the SMTP server without specifying credentials.
    Thanks again!
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Thank you
