Snom 300 and SIP Proxy
Discussion in '3CX Phone System - General' started by Grooverider, Jun 2, 2010.
  1. Grooverider
    Jun 2, 2010
    14
    Hi all
    I am looking for configuration information for connecting the Snom 300 to our 3CX v8 server using the 3CX SIP Proxy tool. Can anyone tell me what settings I need to configure on the Snom handset to work? I could get the 3CX Soft Phone to work using the SIP Proxy software but my Snom handset won't for some reason. I am on the latest V8 Snom firmware.
    Regards
    Gareth Winn
    Ziptech Services Ltd (3CX Partner)
  2. andymars
    Jan 12, 2010
    47
    I would check the IP address and the port the SIP Proxy is running on, then check that your SNOM config actually uses that IP and port (typically 5080 - something i forgot when i setup Linksys/Grandstream phones using the proxy at first)
    <ip address>:<port>
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The 3CX phone has a proxy manager built in, so you wouldnt not need it. The change is quite simple
    External IP and PORT settings in the phone has to be the Internal ip of the compute that is running the SIP proxy manager.
    You must set STUN to off.
    Everything else should be the same.
