Snom 300 call pickup
Discussion in 'Windows' started by yaro, Sep 3, 2009.
  1. yaro
    Jun 11, 2008
    38
    Is that something that needs to be set on the phone or is there function key already there and I just don't know how to use it :) ?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    it's *20*num to pick.
    it's on server.
  3. Discovery Technology
    Apr 19, 2008
    278
    You can program one of the BLF keys as a speeddial with the *20* code to setup a button on the phone (I like using 11 or 12 as it is easy for the users to pick)
    Of course, you also need to purchase a license for this to work as per...
    http://www.3cx.com/phone-system/edition-comparison.html
