Snom 320 BLF
Discussion in '3CX Phone System - General' started by robjbrad, Apr 10, 2008.
  1. robjbrad
    Dec 6, 2007
    6
    I've just installed a new PC with 3CX 5.1. I'm using Snom 320s with 6.5.13 firmware and the BLF appears to be working intermittently. I just wondered if others had experienced this?
    Many thanks,
    Rob
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    It works fine at FW 7.1.30 with 3CX build 4393. Please consider to upgrade it.
    http://www.3cx.com/support/testedphones.html
