Snom 320 web config missing options
Discussion in '3CX Phone System - General' started by coreybrett, May 5, 2011.
  1. coreybrett
    Apr 12, 2010
    72
    I recently updated one of my Snom 320 phones to the 8.4.31 FW.
    I also updated the 3CX provisioning template for Snom and created a new extension for the upgraded phone.
    When I access the web config for the phone, many of the options are missing now.
    Attached are a few screen shots. The old.png file is of a phone that I have not upgraded yet. The new.png file is the phone with 8.4.31 and the new provisioning template applied to the extension.
    Any idea how to get those options back?
      File size:
      6.9 KB
      522
      File size:
      11.2 KB
      522
  2. garyjduk
    Aug 11, 2009
    70
    This is a setting within the Snom config file called Admin mode - at the moment when you updated the firmware it reverted you back to User mode.
    Go to the Snom firmware via 3CX provisioning templates and add the line
    <admin_mode perm="">on</admin_mode>
    Then save the template and reprovision your phones.
    For reference see - http://wiki.snom.com/Settings/admin_mode
  3. coreybrett
    Apr 12, 2010
    72
    Thanks!!!
    I wonder why 3CX has there template set that way?
