Snom 360 shows on display everyone's calls
Discussion in '3CX Phone System - General' started by infomusic, Oct 19, 2010.
  1. infomusic
    Feb 18, 2010
    Hi again, another question..
    On every installation i have, it happens that all the snom 360 show everyone's calls on the display.
    Is it possible to disable this feature?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi ,
    What exactly do you mean by "shows everyones call" ??
