SNOM 370 and OpenVPN
Discussion in '3CX Phone System - General' started by rudym, May 18, 2010.
  1. rudym
    Aug 15, 2008
    36
    Hi all,
    I am trying to configure a SMON 370 phone to connect to a OpenVPN server.
    I m using the 3CX box as the OpenVPN server the server seems to to be working as I am able to connect and access the PBX using a laptop. My problem is getting the phone to connect or loading the client on it.
    I tried putting the tar on the local server \ on the 3CX server (as must SMON instructions indicate" and on an external server. I don't think the problem is related to loading the tar as it shows the following messages during startup;
    Fetching VPN tarbal from: "URL of tarball" (no errors)
    Flashing VPN files (no errors)
    Rebooting to activate VPN" (no errors)
    Starting OpenVPN (no errors)
    But then all I get is a triangle on the lower corner of the phone.
    If I look at the logs I don't see any errors relating to the VPN (not that the log give much information)
    Below is my server config and vpnclient config file. Any help of advice its GREATLY appreciated.
    Rudy
    --- SERVER
    port 1194
    proto udp
    dev tap
    dev-node tap-bridge
    ca ca.crt
    cert server.crt
    key server.key
    dh dh1024.pem
    ifconfig-pool-persist ipp.txt
    server-bridge 192.168.199.29 255.255.255.0 192.168.199.30 192.168.199.35
    push "dhcp-option DNS 192.168.199.200"
    client-to-client
    keepalive 10 120
    comp-lzo
    persist-key
    persist-tun
    status openvpn-status.log
    verb 3
    --- CLIENT
    client
    dev tap
    proto udp
    remote XX.XXX.XXX.XXX 1194
    resolv-retry infinite
    nobind
    persist-key
    persist-tun
    ca /openvpn/ca.crt
    cert /openvpn/phone01.crt
    key /openvpn/phone01.key
    comp-lzo
    verb 3
    keepalive 10 120
