Snom 370 call history
Discussion in '3CX Phone System - General' started by abtec, Nov 4, 2015.
  1. abtec
    Nov 4, 2015
    We are using Snom 370 handsets with 3CX version 12. We have a VOIP provider with several DDI inbound rules added. When the phone rings it displays number of caller on screen, but when you go into the call history it shows calls in following format:
    [RING GROUP NAME]:[DDI NUMBER]:
    Really what we want to see in the history is the number of the person who dialled in. How can we change this behaviour?
    Many Thanks,
    Abtec
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    You may disable the option to show the Ring group name infront of the caller through Settings / General / Global Options / unticking "Add Queue, Group and DID names to Caller ID".
