Snom 370: Custom Logo
Discussion in '3CX Phone System - General' started by r2k, Jul 24, 2012.
  1. r2k
    r2k
    Jan 9, 2011
    23
    Hi Folks,
    i've upgraded to V11. My Company wants to change the default 3CX logo to our one.
    i found the following on the snom page:
    Dimensions:max. 240x128 pixel
    Color Depth: 5 bit (i.e. 32 grey scale colors)
    Format: Windows bitmap (.bmp)
    Encoding: base64
    My problem are these 5bit / 32 gray scale colors. How can I modify this? I've tried this with photoshop and ms paint. But I did not find an option like 5 bit. I only have 4 or 8 bit.
    How can I change this to 5 bit. If there is an program which makes this easily, I would use this :)
    Best regards
  2. r2k
    r2k
    Jan 9, 2011
    23
    I asked snom an got the following answer:
    The only thing i found was the location. I had to change this to:
    <LocationX>0</LocationX>
    <LocationY>0</LocationY>
    original value:
    <LocationX>45</LocationX>
    <LocationY>33</LocationY>
  3. StefanW
    Jun 2, 2009
    1,222
    93
    the image can be saller then the screen size, then you can mode it with the location.
    there is an issue with the firmware and how the logo is displayed.
    the logos i have done for the 370 is correct on the 8.7.4.7 firmware but the firmware is not the best.
    i guess i have to redo ours as well at one stage...
