Snom 370 strange behavior when using BLF's
Discussion in '3CX Phone System - General' started by chrischevy, Sep 13, 2010.
  1. chrischevy
    Jun 7, 2010
    74
    I'm using 3CX 9 sp2 with a snom 370 f/w 8.4.18
    For that Snom 370, I configured a BLF that points to another extension (in 3CX's extensions settings). When that extension makes a phone call, the BLF's lights up (which is normal). The strange part is that on the LCD screen, I see the number that the person dialed in the following format:
    VOIP provider's username, a black losange, dialed phone number.
    On the bottom of the screen, I can press Ok or Cancel. If I press Ok, I take the call (!!!), if i press cancel, the screen goes back to normal and the BLF stays on until the person hangs up.
    On a Snom 320, I don't have this problem. Everything works the way it should work.
    Is there an option on the Snom 370's interface to change this behavior ?
    Thank you
  2. Eurylink
    Eurylink New Member
    May 25, 2008
    174
    Disable the option "Dialog info call Pickup" under Setup -> Advanced -> Behaviour or modify provisioning file.
    Bye
  3. chrischevy
    Jun 7, 2010
    74
    Thanks a lot !
    Actually I found this options like 5 minutes ago !!
    Thank you again
