SNOM 715, hit # to make call
Discussion in '3CX Phone System - General' started by millennium2, Feb 2, 2015.
  1. millennium2
    Apr 8, 2011
    55
    I have a user who is used to hitting the # key on a Yealink Phone in order to Make the Call (after he punches in the number he wants to call). The problem is, we now switched his phone to a SNOM 715 which doesn't seem to allow that feature. If he hits the # key on the SNOM 715 after he dials the number, the # is simply added to the DID and causes an error (i.e. does not make the call).
    Is there a workaround to this, so he can hit the # key on the SNOM to Make The Call, without effecting the other Yealinks in the office?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    To dial the number when the pound key is pressed, please setup the “Dial-Plan String” with:
    !([^#]+)#!sip:\1@\d!d
    This dial plan entry will look for a pattern ending in a pound symbol and use this as the user name in a SIP URI (not including the pound symbol).
    The Dial-Plan String can be found in Setup > Identity x > SIP tab.
  3. millennium2
    Apr 8, 2011
    55
    Hi complex1,
    Just tried this and it worked!
    Many, many thanks. You rock!
