Snom 820 & DND Settings
Discussion in 'Windows' started by swim, Apr 24, 2009.
  1. swim
    Sep 23, 2008
    26
    I have set up free version of 3CX - Sipgate Voip - Snom 820
    If I get first call in on Snom all ok - audio both ways
    If I get second call in whilst on call 1, second call gets dropped
    If I set DND on Snom all calls get dropped
    I cant work this out as I have set 3CX to have setting for Busy on extension to - go to voicemail
    and phone not pbx to administer busy settings - ie allow phone to take simultaneous calls
    Any advise on Snom 820 & 3CX configuration settings would be very gratefully received !
  2. swim
    Sep 23, 2008
    26
    This seems to be problem with DND settings, can someone assist with correct settings for DND on Snom 820 phones and 3CX.
    Calls incoming when DND is set on phones get busy tone, even though extension settings in 3CX have set go to voicemail on busy and use phone status for busy
    log reads
    13:25:18.065 [CM503008]: Call(69): Call is terminated
    13:25:18.065 [CM503015]: Call(69): Attempt to reach <sip:8000@192.168.1.3:5060> failed. Reason: Temporarily Unavailable
    13:25:18.065 [CM503003]: Call(69): Call to sip:1001@192.168.1.3 has failed; Cause: 480 Do Not Disturb; from IP:192.168.1.4:5060
    13:25:18.018 [CM503003]: Call(69): Call to sip:1002@192.168.1.3 has failed; Cause: 480 Do Not Disturb; from IP:192.168.1.5:1024
    13:25:17.940 [CM503004]: Call(69): Calling: RingAll8000:1002Ext.10021001Ext.1001@[Dev:sip:1002@192.168.1.5:1024;line=9b3o2011, Dev:sip:1001@192.168.1.4:5060;line=b3o2011t]
    13:25:17.940 [CM503010]: Making route(s) to <sip:8000@192.168.1.3:5060>
    13:25:17.940 [CM505003]: Provider:[Sipgate3] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.3:5060]
    13:25:17.940 [CM503001]: Call(69): Incoming call from XXXXXXXXXX@(Ln.10002@Sipgate3) to <sip:8000@192.168.1.3:5060>
    Thank you swim
