Snom 820 no outgoing Audio
Discussion in '3CX Phone System - General' started by hasler, Jan 26, 2009.
  1. hasler
    Jan 7, 2009
    20
    I use 3cx 7.0.4744.0 with a Snom 820 and Snom 360 phone.
    While i can call correctly with the 360 I have no outgoing Audio on the 820.
    Does anyone of you have the same problem or give me a possible solution to my problem?
    Thanks for your help,
    Andreas
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    See point 13 of http://www.3cx.com/sip-phones/snom.html . It is most likely to be the cause.
  3. hasler
    Jan 7, 2009
    20
    the encryption is "off", but I have no outgoing audio on the snom 820.
    Thanks,
    Andreas
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    The 820's mic is not set to "mute" by any chance?
    What about the mic volume level being too low?
  5. hasler
    Jan 7, 2009
    20
    Hi I was able to resolve the problem.
    I had to set the "symetric rtp" on "on" under the uses identity.
    Now it works :lol:
    Andreas
