Snom 821 Hold Button with 3CX
Discussion in '3CX Phone System - General' started by the-waves, Aug 15, 2012.
  1. the-waves
    Sep 16, 2008
    5
    Hi all,
    We have a rather large problem with the new Snom 821 handsets we have installed on our network.
    The hold button doesn't work.
    Thats right, with the latest firmware & 3CX version 10 or 11 - the damn hold button does not work.
    My question is - can anybody had any success in getting it working? If so could you share your success story here?
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Unfortunately for Snom the latest firmware has a lot of issues. In fact Snom is not supported anymore by 3CX but you can still use it with 8.4.35 firmware which is the last supported firmware.
  3. tom_ch
    Jul 6, 2011
    69
    we have a lot of Snom 821 here and we never had any problems with the hold button.
    Our Snom 821 are at 8.4.31.
