Solved Snom 870 doenst work with CTI mode
Discussion in '3CX Phone System - General' started by Yiannos Ioannou, Jan 23, 2018.
  1. Yiannos Ioannou
    Nov 13, 2017
    20
    Dear all ,
    I'm facing an issue with one Snom 870 and 3CX Windows client in CTI mode.
    When i enter an external number to the windows client and waiting to send it to the IP Phone , the client calls an internal extension and not the external number , but when i cancel the call from the client the phone is call the external number.
    Im using 3CX 15.5 a Snom870 with FW 8.7.5.44 and a 3CX Client 15.5.7262.2.
    The phone was factory reset and auto provision.
    Thank you
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,412
    186
    Hi Yiannos Ioannou,
    Only a hunch but the snom 8xx series have not been current models for a while now.
    The current publically listed firmware is from 2015:
    http://wiki.snom.com/Snom870/Firmware
    I would take an estimated guess that due to this there maybe some sort of issue with firmware possibly. When you try in CTI mode does the softphone initiate a "MAKE CALL" to the handset ?
    What happens to the call in regards to the deskphone - nothing ?
  3. Yiannos Ioannou
    Nov 13, 2017
    20
    Hello @eddv123 ,
    No it doesn't . It only calls an internal extension and after i cancel the call , then the snom calls the external number
  4. eddv123
    Aug 15, 2017
    1,412
    186
    Have you got another snom model (preferably) current that you can test in CTI mode ?
    As I said my concern is that range went EOL about 3 years ago.
    The other option I think would be to trace the call and see what is going on within Wireshark.
  5. Yiannos Ioannou
    Nov 13, 2017
    20
    Nope is the only Snom phone that we have. The other are yealink and Htek. I think in the 15 version it was working but in the current version 15.5 it stops
    If i downgrade the firmware you think it should work or never mind and get a new one.
  6. eddv123
    Aug 15, 2017
    1,412
    186
    I would not recommend downgrading the firmware unless 3CX is throwing the phone up in red in the "phones" list, as far as 3CX is concerned it has a supported template so should be supported.
    I am going to run a test for you and see if I get the same behavior.
  7. Yiannos Ioannou
    Nov 13, 2017
    20
  8. eddv123
    Aug 15, 2017
    1,412
    186
    Yes it works for me for both internal and external calls tested - works really well actually I am surprised how slick it is compared to some other more current supported models.
    I think you may have to run a trace on this one to see what the issue is.
  9. Yiannos Ioannou
    Nov 13, 2017
    20
    I will
    Thank you
  10. StefanW
    Jun 2, 2009
    1,222
    93
  11. Yiannos Ioannou
    Nov 13, 2017
    20
    Yes now it is working after i remove the first 2 BLFs to lines
    YiannisH_3CX likes this.
