Snom Auto Provisioing not working
Discussion in '3CX Phone System - General' started by tomtom2770, Jun 17, 2017.
  1. tomtom2770
    Apr 2, 2017
    7
    Hello everybody,
    I got an issue with my Snom D765 phones. I want to use auto provisioing for all my phones. They already got a setting url, in their settings: https://mycompany.3cx.ch:5001/rps/cfg{mac}
    They also appear as new devices in the phones section of my 3CX server if I start them, but if I decide to assign one to an extension or create a new extension, the settings seems to be not applied at all. The phone is still waiting for a login, instead of logging into the correct extension.
    The Phones run with firmware version "snomD765-SIP 8.9.3.60" and the server with version 15.5.5
    Thanks in advanced!
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
  3. tomtom2770
    Apr 2, 2017
    7
    No the ip address of the phone is not blacklisted. The problem was a missing port forwarding (5001). Now my phones ask for a login and password. Here starts the next difficulty.
    After I login with my extension id and voicemail pin I can see that it got the right id and extension name, but it still says that the user unregistered.
    What do I do wrong?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,335
    533
    Make sure that the option disallow use outside of lan is not checked in the extension settings / options and try again
