Snom BLF
Discussion in '3CX Phone System - General' started by next2, Sep 14, 2017.
Tags:
  1. next2
    Apr 19, 2009
    39
    We'd like to buy a Snom D712 or D715 as a test, but first I need to make sure BLF works.
    Looking at the provisioning help page https://www.3cx.com/sip-phones/snom-710-720-760/
    I see BLF LED will show monitored extensions in idle. Does it mean that, while in conversation, the BLF leds will not work ? This would make the BLF useless, as people look at it prior to transfer a call for example.
    Can you confirm ?
    Thank you !
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hello @next2 ,
    If you are about to buy one of those IP phones i would suggest the D715 that is supported, D712 has not been tested and thus not supported.
    the behavior on Snom D715 is:
    -extension is idle: BLF is on
    -extension is engaged: BLF is blinking
    Hope this helps.
