Solved Snom BLFs bulk update?
Discussion in '3CX Phone System - General' started by Joao Custodio, Feb 16, 2018.
  1. Joao Custodio
    Feb 1, 2018
    7
    Is there a way to provision multiple extensions with the same BLF settings? I know that by holding CTRL I can select multiple, but I don't see how to send BLF settings to all of them!
    I'm using Snom D725 phones with latest supported firmware and custom templates
    Regards
    Joao Custodio
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
    Hello @Joao Custodio
    As you've already said, hold the CTRL and select all the extensions that will have the same BLFs. Then click on edit, go to BLF Tab and configure the BLFs as needed.
    Then go to MMC >> Phones, select all the relevant phones, again holding CTRL and click on Reprovision
    Joao Custodio likes this.
  3. Joao Custodio
    Feb 1, 2018
    7
    Hi mariosM_3CX
    By holding CTRL and selecting more than one extension the "Edit" gets greyed out...
    UPDATE: My bad, I was selecting the phones instead of extensions!
    All fixed now. Regards
  4. mariosM_3CX
    Nov 1, 2017
    401
    36
