Solved Snom C520 WiMi
Discussion in 'Windows' started by Pambos, Mar 21, 2018.
  1. Pambos
    Mar 21, 2018
    i have this phone which is still not supported by 3CX , i have assigned to the phone an extension , but i'm facing a weird issue the phone extension calls to it self every 15 minutes ,
    any idea on how to solve this
  2. Pambos
    Mar 21, 2018
    i'm new to 3CX so if any clarification is needed i can provide
  3. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    Hello @Pambos,
    I have sent you a P.M
    Thank you
  4. Angelo Quaglia
    Feb 9, 2018
    5
    What was the solution?
  5. Marios Neophytou
    Mar 1, 2016
    258
    12
    Please check your inbox
    Thank you
  6. Lluis
    Dec 13, 2017
    Hi Marios. We have the same problem witn the snom C520. Can u send us the solution?
    thanks and regards,
  7. Marios Neophytou
    Mar 1, 2016
    258
    12
    The solution for this is as follows:
    1. Go to Management Console > Settings > Parameters and search for CSTA_USER_AGENTS Parameter .
    2. Replace the value of this parameter with the value below:
    Fanvil X,Fanvil C400,Fanvil C600,Fanvil H,Htek UC8,Htek UC9,snom3,snomD,snom7,snom8,Yealink SIP-T19P_E2,Yealink SIP-T19_E2,Yealink SIP-T23,Yealink SIP-T27,Yealink SIP-T29,Yealink SIP-T4,Yealink SIP-T5,Yealink SIP-CP920,Yealink SIP-CP960,GrandStream GXP2170,GrandStream GXP2160,GrandStream GXP2140,GrandStream GXP2135,GrandStream GXP2130,GrandStream GXP17,GrandStream GXP16
    3. Restart all PBX services
    Lluis likes this.
