SNOM call pickup *20*: No caller-ID update
Discussion in '3CX Phone System - General' started by jandings, Sep 17, 2010.
  1. jandings
    Jun 26, 2008
    7
    I am using the latest V9 3CX and numerous SNOM 320 phones with different 7/8 firmwares.
    When I pick-up a call from a SNOM by dialing *20*<EXT> <OK> I get the call. But the display still reads *20*<EXT> and NOT the Caller-ID of the caller. Same with pushing BLF button.
    Any idea how to solve this?
    Thanks,
    Jan
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    I'm using an Aastra 6753i and have same issue.
  3. tom_ch
    Jul 6, 2011
    69
    Doesn't work in our environment either. We use Snom 821.
  4. leejor
    10,737
    278
    Re-invite setting/issue?
  5. craigreilly
    Feb 1, 2012
    3,311
    249
    I had Supports Re-Invite/Support 'Replaces' header enabled on the handset that put the call on hold - but not on the one picking it up. Both have same settings and now it works for Global Parks. For *20*<ext> it got the caller id, but not the name.
    strange - I'd expect it to work the same on both.
  6. 3CXNewbie
    Jul 18, 2013
    22
    Having same issue with 3CX 12 and Yealink phones. Turned Support Re-invite and Support Replace Header on for extension making call, extension receiving call and extension picking up call as test, but display still says *20*.
    Thanks.
  7. miko
    Oct 14, 2011
    7
    Did anyone get to the bottom of this?
