snom D345 - Firmware 8.9.3.46 not supported [solved]
Discussion in '3CX Phone System - General' started by thinkagain, Nov 17, 2016.
  1. thinkagain
    May 2, 2014
    I installed a new snom D345 Deskphone and added it to our 3CX (V15 SP3).
    The Phones list reads, that the firmware Version "8.9.3.46" is not supported. Another firmware version isn't available.
    Provisioning works - but not all functions, e.g. the DND-Button isn't working.
    3CX says, that all snom phones will worx with 3CX - so what ist the right firmware for D345?
    Thanks for your help.
    Joe
  2. thinkagain
    May 2, 2014
    Re: snom D345 - Firmware 8.9.3.46 not supported
    Solved.
    I downgraded to 8.9.3.38 - and everything works.
