Snom D715 BLF and update 15.5 SP1
Discussion in '3CX Phone System - General' started by av23, Aug 10, 2017.
  1. av23
    Aug 10, 2017
    I am using Snom D715 phones with standard template.
    Before updating to SP1, BLF LED pattern was:
    • Extension is available: LED is off
    • Extension is ringing: LED is blinking
    • Extension is busy: LED is on
    Now, since updating to SP1 (both 3CX and the phones’ firmware), BLF LED pattern is:
    • Extension is available: LED is on
    • Extension is ringing: LED is off
    • Extension is busy: LED is off
    Is that normal behavior ?
    If so, this is very impractical: it is counter intuitive as LED patterns for monitored extensions now works differently than LED patterns for the user’s own line keys but most importantly it is now impossible to make the distinction between a monitored extension that’s busy and one that’s ringing (which is necessary for call pickup).
    Is there any option to revert to the old LED pattern?
    I tried creating a custom template, but I can't figure out the correct config to use. Is there any way to get the template for the previous version back so I could copy the old BLF config to a custom template?
    Thanks,
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,350
    452
    Hello @av23
    Please note that there is currently a bug in Snom's latest firmware that is affecting the BLF functionality in models 715, 712 and 710.
    However the behaviour for these models has changed and the behaviour should be
    • Extension is busy: LED is Red or Off (depending on the phones capabilities)
    Please keep an eye out for any updates in Snom firmware that will resolve this issue. Once we have the fix we will provide an update through the PBX
  3. oxiale
    Sep 23, 2015
    i have the same problem on my D715, any news ?
    actually, with firmware 8.9.3.66 :
    • Extension is available: LED is on (green)
    • Extension is ringing: LED is blinking (green)
    • Extension is busy: LED is on (green)
    Thx
  4. oxiale
    Sep 23, 2015
    with downgrade in 8.9.3.38, it's working...
