malone
- Joined
- May 30, 2016
- Messages
- 7
- Reaction score
- 0
All of our SNOM D715 phones are having the below issue connecting to a internal 3CX server - any ideas? The auto provisioning appears to be working...
Note also the phones are not appearing in the auto provisioning page of 3CX - they have to be manually added.
May 29 23:34:36 [INFO ] PHN: ProvisioningReplacements: URL >http://pbx.example.com.au:5000/provisioning/biugn9fn0s/firmware/snom/snom715.xml<
May 29 23:34:36 [DEBUG0] PHN: Uri Replace >{mac}< in >http://pbx.example.com.au:5000/provisioning/biugn9fn0s/firmware/snom/snom715.xml<
May 29 23:34:36 [DEBUG0] PHN: Uri Replaced result: >http://pbx.example.com.au:5000/provisioning/biugn9fn0s/firmware/snom/snom715.xml<
May 29 23:34:36 [DEBUG0] PHN: ReplaceQueryVariables in >http://pbx.example.com.au:5000/provisioning/biugn9fn0s/firmware/snom/snom715.xml<
May 29 23:34:36 [DEBUG0] PHN: ReplaceQueryVariables replaced: >http://pbx.example.com.au:5000/provisioning/biugn9fn0s/firmware/snom/snom715.xml<
May 29 23:34:36 [NOTICE] PHN: Fetching FW URL: http://pbx.example.com.au:5000/provisio ... nom715.xml
May 29 23:34:36 [NOTICE] PHN: Fetching URL: http://pbx.example.com.au:5000/provisio ... nom715.xml
May 29 23:34:36 [DEBUG2] WEBCLIENT: Send TCP none
May 29 23:34:36 [DEBUG2] WEBCLIENT: Socket 23 connecting
May 29 23:34:36 [NOTICE] PHN: Last provisioning was successful, thus stop here!
May 29 23:34:36 [NOTICE] PHN: Go to wizzard if all settings have been read.
May 29 23:34:36 [NOTICE] PHN: SetProvisioningDone
May 29 23:34:36 [NOTICE] DNS: Starting dns proxy...
May 30 09:34:36 [NOTICE] PHN: DST start 02.10.2016 02:00:00 end 03.04.2017 03:00:00 offset 3600
May 30 09:34:36 [NOTICE] PHN: Setting automatic settings refresh timer with 86400 seconds
May 30 09:34:38 [ERROR ] PHN: TPL: Socket Error: 22/33/connected, Tls error, closing
May 30 09:34:38 [NOTICE] PHN: Fetching FW URL: http://pbx.example.com.au:5000/provisio ... rmware.htm
May 30 09:34:38 [NOTICE] PHN: Fetching URL: http://pbx.example.com.au:5000/provisio ... rmware.htm
May 30 09:34:38 [WARN ] SIP: transaction_timeout udp: 1000001 (32500)
May 30 09:34:38 [ERROR ] SIP: transport error: 1000001 -> udp:10.0.0.11:5060
May 30 09:34:38 [NOTICE] SIP: Add dirty host: udp:10.0.0.11:5060 (0 sec)
May 30 09:34:38 [ERROR ] SIP: request 1000001 destination invalid udp:10.0.0.11:5060 3134363435363438373833313239-4nxigrb000d8
May 30 09:34:38 [NOTICE] SIP: final transport error: 1000001 -> udp:10.0.0.11:5060
May 30 09:34:38 [ERROR ] SIP: transport error 1000001: generating fake 599
May 30 09:34:38 [ERROR ] SIP: Registrar [email protected]:5060 timed out
May 30 09:35:22 [NOTICE] PHN: DST start 02.10.2016 02:00:00 end 03.04.2017 03:00:00 offset 3600
May 30 09:35:22 [NOTICE] CFG: Std-Settings stored
May 30 09:35:22 [NOTICE] CFG: FKey-Settings stored
May 30 09:35:22 [NOTICE] CFG: TBook stored
May 30 09:38:45 [NOTICE] PHN: TPL: Socket 28 idle/connect timeout
May 30 09:38:47 [NOTICE] PHN: TPL: Socket 26 idle/connect timeout
May 30 09:38:47 [NOTICE] PHN: TPL: Socket 27 idle/connect timeout
May 30 09:38:47 [NOTICE] PHN: TPL: Socket 29 idle/connect timeout
May 30 09:38:47 [NOTICE] PHN: TPL: Socket 30 idle/connect timeout
May 30 09:38:50 [NOTICE] PHN: TPL: Socket 31 idle/connect timeout
May 30 09:38:54 [NOTICE] PHN: TPL: Socket 32 idle/connect timeout
May 30 09:39:03 [NOTICE] PHN: TPL: Socket 33 idle/connect timeout
