Solved Snom D725 Firmware issue
Discussion in '3CX Phone System - General' started by Joao Custodio, Feb 28, 2018.
  1. Joao Custodio
    Feb 1, 2018
    7
    Hi all,
    Something here confusing me a bit...
    I have a 3CX v15.5 system with Snom D725 phones, one of the phones (ext. 307) is showing the latest firmware on the GUI..
    [​IMG]
    but on the Management console is showing an unsupported firmware...
    [​IMG]
    I've tried downgrading, upgrading, provisioning, rebooting and even assigning the phone to a different extension with no success.
    Any ideas?
    Best Regards
    Joao Custodio
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
  3. Joao Custodio
    Feb 1, 2018
    7
    @YiannisH_3CX
    U
    pdating the firmware manually made no diference
  4. Joao Custodio
    Feb 1, 2018
    7
    I've just fxed the issue,
    I had a backup copy of the Settings file that I took before the last firmware update, as I had been doing some testing with that phone I uploaded the file to the phone and even the phone having the latest firmware, the file had references to the old one.
    After uploading a settings file from a phone with a recent firmware the issue got fixed.
    Regards
  5. YiannisH_3CX
    May 10, 2016
    7,301
    530
    Glad to see the issue has been fixed and thank you for sharing your solution
