Solved SNOM D785
Discussion in '3CX Phone System - General' started by Rolf Puerckhauer, Apr 12, 2018.
  1. Rolf Puerckhauer
    Aug 22, 2017
    5
    the SNOM D785 is listed as supported, but it is not recorgnized in Phones and manual adding doesn't work.
    my 3CX has the latest official version.
    How can I use the Snom D785?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,063
    57
    It is listed in the provisioning files and manual provisioning will also work. It would help to know if on the same LAN, if the firmware is updated and whatever else you can tell us other than it doesn't work. Perhaps the IP is blacklisted?
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,004
    153
    Its in the snom template in 3CX: <model ua="snomD785">Snom D785</model>.
    I think it maybe a deeper issue than this. If the device is on the local LAN please first confirm whether any other supported models appear in the phones list on 3CX or not and if not take a look at this guide: https://www.3cx.com/docs/plug-and-play-ip-phone/
  4. StefanW
    Jun 2, 2009
    1,203
    82
    if you never had a snom device before, template updates are supressed for models you dont have.
    Create a fake snom device for now in an extension.
    in 2min under updates a snom update should be seen...
  5. Rolf Puerckhauer
    Aug 22, 2017
    5
    After adding a fake device I updatet snom templates.
    After that I was able to manually add the device.
    But not I have an incompatible firmware on this phone (firmware is 10.1.20.0)
  6. SIPlink
    Jul 12, 2016
  7. Rolf Puerckhauer
    Aug 22, 2017
    5
    Thanks a lot.
    Now it works perfekt.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,891
    321
    Glad to see the issue has been resolved
