SNOM DECT (M700 Base, M65 handset)
Sorby
Hi!
Is there someone who knows how to get the 3CX address book on to the SNOM DECT handsets?
Hi Sorby
It did used to work without any need for config, but since firmware v355 you need to make a change to your provisioning template, i think it's a firmware bug, or something has changed that no longer works with the default 3CX template
find the line in your 3CX template that shows <phonebook_server_location>0</phonebook_server_location> and change it to <phonebook_server_location>2</phonebook_server_location>
0=local and 2=XML server, so it needs to be 2 for XML server.
I've only tested this on 3CX v14 so can't comment on v15 but in theory the same should apply
Seems to work in 15.5 linux.
Getting Started - Admin
Dozer302
Get 3CX - Absolutely Free!
3CX
