SNOM hide caller no outbound calls
Discussion in '3CX Phone System - General' started by jens.hartmann, Nov 3, 2017.
  1. jens.hartmann
    Nov 29, 2016
    8
    When we supress the number on a SNOM Phone we can't do outgoing calls. Is this a known issue?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Most probably this is an issue with provider, not with SNOM phones. How you suppress the number ?
    Can you make internal calls? Test suppressing also with 3CX softphone.
