Snom Idlescreen
Discussion in '3CX Phone System - General' started by Schlendermann, Mar 2, 2017.
  1. Schlendermann
    Mar 2, 2017
    since the last Update the idlescreen on our snom phones is gone.
    Any hints to get it back?
    Regards,
    Rafael.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @Schlendermann
    What do you mean by latest update? The latest service pack update or the latests updates on the updates section?
    Have you downloaded the latest templates and firmware for snom phones which are intended for SP5 release?
  3. Schlendermann
    Mar 2, 2017
    yes updated to the latest templates / firmware for snom phones. I got the update suggested by the updates section.
    I didn't realise that it's only for SP5.
    Regards,
    Rafael.
  4. YiannisH_3CX
    May 10, 2016
    7,400
    535
    Please upgrade to SP5 since it was released today and reprovision your phones.
    Let us know if this resolves your issue
  5. Schlendermann
    Mar 2, 2017
    I did the update. Now the phones have a new "3cx"-background image, but the idle screen
    is still disabled.
    Regards,
    Rafael.
