Snom M3 and proxy tunnel
Discussion in '3CX Phone System - General' started by asdesign, Jul 9, 2010.
  1. asdesign
    Jul 9, 2010
    Am trying in vain to get a snom m3 connected via the proxy tunnel from remote site via vpn
    The proxy log is as below - I can't see any activity for it on the server log so know it isn't getting that far
    I have checked the 3cx server side settings network 3cx tunnel is expecting to see it on port 5090 and 5.2.111.148
    \TCPSide.cpp(155) : {14:20:15.234}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
    .\TCPSide.cpp(155) : {14:20:44.265}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
    .\TCPSide.cpp(155) : {14:21:13.312}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
    .\TCPSide.cpp(155) : {14:21:42.343}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
    .\Stack.cpp(102) : {14:22:01.906}(Trace5):Received from local SIP stack(5080):
    brief=SipReq: REGISTER 192.168.1.64:5080 tid=e4tbl.ilbcj3c82ubypo2m646e8yjj cseq=REGISTER contact=13@192.168.1.68 / 167379 from(wire)
    .\Stack.cpp(215) : {14:22:01.906}(Critical0):RL is of tunnel, but Route doesn't exists
    .\Bridge.cpp(304) : {14:22:01.906}(Trace5):processing SIP message (tid=e4tbl.ilbcj3c82ubypo2m646e8yjj) from SIP stack 192.168.1.64:5080
    .\Bridge.cpp(571) : {14:22:01.906}(Trace5):preprocessing local SIP request: REGISTER, tid=e4tbl.ilbcj3c82ubypo2m646e8yjj
    .\Bridge.cpp(812) : {14:22:01.906}(Trace5):Not valid Route: sip:192.168.1.64:5080
    .\Bridge.cpp(820) : {14:22:01.906}(Trace5):Outbound tunnel (5.2.111.148) is selected
    .\Bridge.cpp(632) : {14:22:01.906}(Trace5):process local request: REGISTER
    .\Bridge.cpp(355) : {14:22:01.906}(Trace5):Tunnel to 5.2.111.148:5090 is selected for SIP message (tid=e4tbl.ilbcj3c82ubypo2m646e8yjj)
    .\TCPSide.cpp(155) : {14:22:11.359}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
    .\Bridge.cpp(408) : {14:22:34.406}(Trace5):Got SIP msg
    brief=SipResp: 408 tid=e4tbl.ilbcj3c82ubypo2m646e8yjj cseq=REGISTER / 167379 from(tu)
    from tunnel's connection 5.2.111.148:5090
    .\Bridge.cpp(423) : {14:22:34.406}(Trace5):Selected SIP stack on 192.168.1.64:5080
    .\Bridge.cpp(734) : {14:22:34.406}(Trace5):process tunnel response: 408 Request Timeout / REGISTER
    .\Stack.cpp(162) : {14:22:34.406}(Trace5):Sending to stack(5080);
