snom m3-gives "busy signal" instead of hanging up
Discussion in '3CX Phone System - General' started by Anonymous, Jul 24, 2008.
  1. Anonymous
    Anonymous Guest
    Hi Matt,
    We are not able to reproduce this internally with our M3.
    What gateway are you using? We have seen this with analog gateways which do not correctly recognise the tones.
    Are you bound to PBX?
