Snom m3 one way speeach
Discussion in '3CX Phone System - General' started by George Georgiou, Mar 28, 2009.
  1. George Georgiou
    Jul 21, 2007
    22
    I have the latest version on both systems 3cx 7.1 and snom-m3-SIP/01.22//28-Oct-08 10:42.
    All faction works just fine except for the external calls i have only one way speech.
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    External calls coming in to the M3 or from the M3 to external numbers?
    Can you post the server logs showing a call with one way audio?
  3. George Georgiou
    Jul 21, 2007
    22
    I test Snom m3 with Patton gateway and it works fine. The problem i face is with Linksys gateway 3102.
    I have external call ring the other party can hear me but i can not here them?
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Check the codec's used in the 3102 and the order they are in.
    Did you set up the SPA-3102 as per the 3CX guide?
