SNOM M9 phone on Ver12
Discussion in '3CX Phone System - General' started by biker29, Feb 27, 2014.
  1. biker29
    Feb 27, 2014
    I have M9 phones on my Ver 12 system. They work fine BUT, the "go to sleep" sometimes for no apparent reason. If i use the phone to call (even internally) it will "wake up" and start ringing in the queue as normal.
    VERY frustrating, and ideas?
    Thanks!!
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    I have tested both the M3 and M9 and did not see this issue... but the M9 has terrible g722.. avoid in favor of g711u.
  3. biker29
    Feb 27, 2014
    Thank you for the time taken to look at this. I tried to place an internal call (from ext. 1010) this morning, and the phone (ext 1015) was "dead". This is what i got:
    07-Mar-2014 08:53:52.352 [CM503008]: Call(C:128859): Call is terminated
    07-Mar-2014 08:53:52.351 Leg L:128859.1[Extn] is terminated: Cause: CANCEL from 84.94.76.58:5062
    07-Mar-2014 08:53:35.324 Currently active calls - 1: [128859]
    07-Mar-2014 08:53:23.877 [CM503025]: Call(C:128859): Calling T:Extn:1015@[Dev:sip:1015@84.228.183.61:3021;transport=udp;line=cd84lb] for L:128859.1[Extn]
    07-Mar-2014 08:53:23.827 [CM503027]: Call(C:128859): From: Extn:1010 ("1010" <sip:1010@85.159.235.142:5060>) to T:Extn:1015@[Dev:sip:1015@84.228.183.61:3021;transport=udp;line=cd84lb]
    07-Mar-2014 08:53:23.827 [CM503004]: Call(C:128859): Route 1: from L:128859.1[Extn] to T:Extn:1015@[Dev:sip:1015@84.228.183.61:3021;transport=udp;line=cd84lb]
    07-Mar-2014 08:53:23.825 [CM503001]: Call(C:128859): Incoming call from Extn:1010 to <sip:1015@85.159.235.142:5060>
    Does that help any?
    Appreciate the assistance! Allen
