Snom m9 supported
Discussion in '3CX Phone System - General' started by webactive, Apr 10, 2011.
  1. webactive
    Apr 10, 2011
    Can anyone advise if m9 phone is supported by 3cx?
    And how easy is it to setup?
    http://www.snom.com/en/products/voip-dect-phones/snom-m9/
    Many thanks matt
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    From what we were told at the 3CX partner training in February, SNOM handset support is being deprecated. Again, you should be able to get basic functionality working with manual configuration. Automatic provisioning is another matter.
