Snom PA1 strobe
Discussion in '3CX Phone System - General' started by bbaker73, Oct 27, 2017.
  1. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    123
    21
    Can anyone point me to any setup documents on wiring/configuring the Snom PA1 with a speaker and/or strobe? I'd like to set up paging to activate a strobe.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi bbaker,
    The PA1 is still supported in the 3CX>snom provisioning template.
    All the documentation I can find on the PA1 and 3CX can be found here:
    https://www.3cx.com/sip-phones/provisioning-snom-pa1/
    http://wiki.snom.com/Snom_PA1/Documentation
    http://downloads.snom.net/documentation/UM_PA1_en.pdf
    I used one of these with 3CX and a speaker and it worked perfectly well. Connect the devices wires to the speaker terminals labelled "Speaker". Connect the "+" wire with the red terminal, connect the "-" wire with the black terminal that should be it.
    bbaker73 and YiannisH_3CX like this.
  3. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    123
    21
    Thank you!
