Snom Question
Discussion in '3CX Phone System - General' started by ginis, May 15, 2008.
  1. ginis
    May 15, 2008
    I have downloaded 3cx and i am testing it with snom 360 and 320 phones.
    How can i program the message fuction key to see only if i had messages in my voicemail and not the missed calls
    and how can i program the retrieve fuction key to login automaticly without asking username and pin number
    Can this be done
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    This can be done, and actually you don't even need to specificly program Snom. But Message waiting indicator is available only in licensed versions.
    Re message retrieval: it is improved in V6. You don't need to enter extension number by default.
  3. ginis
    May 15, 2008
    Thanks Archie for the reply
    Can i ask something else
    How can i do conference with voip client and in the manual says that users can log in and logout from queues or
    change the status of the user What if i don t want the user to change all this
    Can i give permissions to users?
    Thanks in advance
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Don't waste your time :) V6 has normal conference places
