SNOM Templates
Discussion in '3CX Phone System - General' started by complex1, Jul 16, 2014.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
    I have an issue with provisioning SNOM phones. (SNOM 300, 320 and 760)
    When the phones are provisioned by the default SNOM templates the “Customised Alert-Info using built-in melodies:” are not setup.
    The “Internal Ringer Text:” fields stays empty, also “Internal Ringer File:” are not changed.
    I have checked both templates (300 and 320/760) but see no strange “things”. It should work, but it doesn’t.
    Is this a known (phone) issue or do I forget something to do?
    Thanks.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Are your snom in fw 8.7.3.25 (latest supported) ?
    Are you up-to-date on templates (see 3CX Phone System Updates / Phone Provisioning Updates) and using defaults ?
    Is this same after factory reset / reprovisioning ?
  3. complex1
    Jan 25, 2010
    788
    45
    Hi Pierre,
    Thank you for your reply.
    The Snom is running on fw 8.7.3.25
    I have downloaded the latest template (Snom 3x0, 7x0, 8xx) and using default settings
    Execute a Factory reset and reprovisioning the Snom
    Issue is still there.
    [​IMG]
