Snow 370 not registering
Discussion in '3CX Phone System - General' started by Paddy, Jun 14, 2013.
  1. Paddy
    Jun 14, 2013
    Hi All,
    I'm trying to register a Snom 370 but I'm unable to do this. I have tried to Auto provision the phone and to provision it manually but with no luck.
    I have upgraded the firmware and reset the phone too.
    Please see attached my phone settings. I have tried two options in an effort to get it registered.
    I have verified the logon details and password are correct on another phone and they are fine.
    192.168.0.12 is the IP of the PBX
    Ext: 248
    Here is the message from the 3CX Logs
    14-Jun-2013 16:11:07.522 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.0.101:1028 tid=-6oviw8d9eb3h Call-ID=3c267029aeac-beelyqeqqkx8:
    REGISTER sip:192.168.0.12:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.101:1028;branch=z9hG4bK-6oviw8d9eb3h;rport=1028
    Max-Forwards: 70
    Contact: <sip:248@192.168.0.101:1028;line=rdiz2tc1>;q=1.0;+sip.instance="<urn:uuid:fff1f8db-9ef7-4ac3-8b14-eeb1e965f44a>";mobility="fixed";description="ip840c";actor="principal";events="dialog";methods="INVITE,ACK,CANCEL,BYE,REFER,OPTIONS,NOTIFY,SUBSCRIBE,PRACK,MESSAGE,INFO";flow-id=1;audio;duplex="full"
    To: "john Doe"<sip:248@192.168.0.12:5060>
    From: "john Doe"<sip:248@192.168.0.12:5060>;tag=eqbvwnjg48
    Call-ID: 3c267029aeac-beelyqeqqkx8
    CSeq: 34 REGISTER
    Expires: 3600
    Proxy-Authorization: Digest username="248",realm="3CXPhoneSystem",nonce="414d535c07cbc38b63:c33434de5d09bf4201de73b2205da6dd",uri="sip:192.168.0.12:5060",response="0fb4f7cab1b12b6bca31435085a318eb",algorithm=MD5
    Supported: gruu
    User-Agent: ip840c/7.1.31
    Allow-Events: dialog
    Content-Length: 0
    X-Real-IP: 192.168.0.101
    Here is the log from the phone
    [5]24/12/2001 00:00:19: read_xml_settings: found dial-plan XML header
    [5]24/12/2001 00:00:33: Setting server received via DHCP: http://192.168.0.12:5000/provisioning/cfg{mac}
    [5]24/12/2001 00:00:33: Fetching URL: http://192.168.0.12:5000/provisioning/cfg001D29001415
    [5]24/12/2001 00:00:36: Fetching URL: http://127.0.0.1/dummy.htm
    [2]24/12/2001 00:00:36: start_dst(985485600) end_dst(1004238000) offset_dst(3600) offset_utc(0)
    [2]24/12/2001 00:00:36: start DST: 03/25/2001 02:00:00 (985485600)
    [2]24/12/2001 00:00:36: end DST: 10/28/2001 03:00:00 (1004238000)
    [5]24/12/2001 00:00:37: read_xml_settings: found phone-book XML header
    [5]24/12/2001 00:00:41: Opening TCP socket on port 80
    [5]24/12/2001 00:00:41: Opening TCP socket on port 443
    [5]24/12/2001 00:00:44: Add dirty host: udp/192.168.0.12/5060
    [5]24/12/2001 00:00:44: timeout::callback: Registering with timeout of 0 ms
    [2]24/12/2001 00:00:44: Transport Error: Pending packet 1000000: generating fake
    [2]24/12/2001 00:00:44: Registrar 248@192.168.0.12:5060 timed out
    [5]24/12/2001 00:01:03: Settings applied!
    Again the login details are fine.
    Can someone maybe shed some light on what exactly is happening?
    Many thanks.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Option 2 should work, but there are a few things to do:
    - Clear Outbound Proxy field
    - Type your password, do not copy/paste.
    - Check in 3CX if the phone IP is not blocked.
