Sodtphone, VOIP Phone DHCP address
Discussion in '3CX Phone System - General' started by petewatterschats, Feb 28, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    If the IP Phones, and softphones have a DHCP IP address lease that can change over time - does this become an issue when the IP Address changes. Should IP Phones have static addresses
  2. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    With 3CX it is not necessary for ip phones to have static addresses.
    Allen
  3. leejor
    10,360
    226
    While it is true that a phone, or ATA does not have to have a static IP, it is helpful, if the device has a GUI that allows you to log-in and make changes. SIP devices (phones and ATA's) don't require a static IP because they re-register with 3CX within 30 minutes, and keep doing this. In this manner, the server always knows what devices are available and where to reach them. This is different in the case of a gateway, such as the SPA-3102, which you are going to test. The IP (and port) of the gateway is datafilled in the 3CX trunk settings so the device must have a static IP.
